Current to spark plug leads when ignition is switched on....
cadman
Post by cadman » Thu Jul 25, 2013 5:31 pm
If you pull plug attach the plug wire hold the plug against ground does it fire the plug? I am assuming you think this is your runnig problem.
downtoscratch
Post by downtoscratch » Thu Jul 25, 2013 5:34 pm
cadman wrote:If you pull plug attach the plug wire hold the plug against ground does it fire the plug? I am assuming you think this is your runnig problem.[/quote
Thanks cadman
