Searching for 1963 C105 55cc wiring diagram
revlover
Post by revlover » Sun Sep 04, 2016 10:01 pm
Rizingson wrote:Have you pulled the flywheel and checked/cleaned the points? Also clean any rust from the inside of the flywheel. The coil on the left or closer to the rear is the primary coil, the other coil is the lighting coil.
I might be wrong, but I think it's possible to clean and adjust the points through the hole in the flywheel. You will have to remove the flywheel to replace the points though.
