adding blinkers/winkers
jensen
- Contact:
With the new type front fork came the new style winkers. In Germany these winkers where a little different, but more or less the same style. The front winkers are rare, but not as rare as the square type. These winkers are bolted on the lever holder (perch) as pictured in the manual. In the past ten years I found a dozen complete sets, no more. Most of them needed repair, but these gems are worth it.
jensen
- Contact:
These (rear) winkers are also used for the front side, but then bolted on the head lamp, sometimes directly or sometimes with a spacer (regulations). This type of winkers is also used on the CB450 BB, at least in the Netherlands.
jensen
- Contact:
Then there are the police version winkers, these winkers are different then the standard ones, but also in two styles, square and round. I'm not sure, but I think the style was chosen by the police force, and differs from country to country. I have both types somewhere lying around, but I could not find them for picturing, when I find them I will take a picture to complete. These styles are seen on cb's from the far east, and these are rare (at least here in the Netherlands)
jensen
- Contact:
Then there are winker switches. I saw a lot off different winker switches, left side, right side, and all appears original to me. Here I picture my original dutch switches, strange, but original CB72. On my left side of the handle bar there is my light switch, printed with a D (Dimlicht, dutch for low beam) and a G (Grootlicht, dutch for high beam). This switch also holds the gas handle or twist grip as you call it.
In the Netherlands the winker switch is sometimes on the left side, sometimes on the right side. Late style switches are always left sides by regulations (you cant not control the twist grip and switch the winkers on and off with one hand, at least that's the official statement.
There is also a cut away in both switches (see pictures below), I don't know if this is original or not, but I guess not.
