I am at a loss, I thought it was low compression but
silverclerk@gmail.com
- h305 Moderator
If you completely remove the stator and place it around the rotor whilst you do the violent bit it will act as a keeper ring.
Place both items on a piece of sheet timber (plywood works OK) but work on a concrete base as a datum; staking on a bench, other than directly over a vertical (leg) which is firmly at datum level, is a no-no, as the bench top will just 'give' with the impact and create the need to belt it harder.
