Handlebar options
dreamneworleans
Handlebar options
Post by dreamneworleans » Tue Nov 18, 2014 10:30 pm
I have 67 Dream that I recently bought. It came with motocross type handlebars. What is a good source for original or aftermarket handlebars? I might be interested in some that are a little lower... Any advice is appreciated.
Post by G-Man » Wed Nov 19, 2014 2:42 am
The original handlebars have slots to take the wiring and the throttle mechanism. Originals come up on eBay occasionally but if you are handy you can use almost anything and cut those slots yourself.
http://www.ebay.com/sch/i.html?_from=R4 ... r&_sacat=0
I have seen Dreams with CB72-style flat handlebars but you could use something from a range of small Hondas.
Waveblaster
Post by Waveblaster » Thu May 14, 2015 5:03 am
I have a Benly C92 and the bars are the same as the Dream . Slot is included.
Try these
http://www.ebay.com/itm/Honda-Benly-125 ... 08&vxp=mtr
regards
Greg
OldScrambler
Post by OldScrambler » Mon May 18, 2015 9:35 am
............almost the 'same'..........slightly narrower.......and slightly different bend........ but will work.
Waveblaster
Post by Waveblaster » Mon May 18, 2015 6:31 pm
Hmmm. I will have to double check that this evening. Unless one has the incorrect one fitted. I seem to recall putting the two sets next to each other.
will305
Post by will305 » Fri Jun 12, 2015 6:38 pm
G-Man wrote:The original handlebars have slots to take the wiring and the throttle mechanism. Originals come up on eBay occasionally but if you are handy you can use almost anything and cut those slots yourself.
G-Man,
Is there a thread somewhere (sure there is) with tips on install new low bar and running the wires internally? I don't want to take the controls further apart than necessary since I know they're tough to put back together sometimes.
Thanks,
Will
1965 CB77 Superhawk
1967 Chevelle SS Tribute 4 Speed
1967 Chevelle Malibu Auto
1998 Corvette, 10k miles!
Post by G-Man » Sat Jun 13, 2015 12:26 am
Will
Yes - there must be. Either use the search here or do a Google search and use "Honda 305 forum" in the search line and it helps find stuff on this site....
http://www.honda305.com/forums/low-rise ... t3028.html
G-Man,
Thanks,
Will
