Need Keys for Honda Dream 305
I recently purchased two 305 projects without keys. I've heard there may be a way to get some ID numbers from the key switch and then contact a Honda dealer to see if they still have any of these old keys. I'm not sure of the process or whom to contact by way of a dealership. Any info is appreciated.
I got some from Hondakeys.com and also a local locksmith made me some.Also bought one on Ebay.Some of the other Honda models of that vinatage used the same key codes but the key blank was shaped alittle different but will still work.Look at photo, one on left I got on Ebay and one on right is the normal size blank, but that one is an old key but not original.
http://www.reproductiondecals.com/defau ... .html~main
I guess that doesn't link so well.
Click on NOS parts and then on Honda Keys.
Re: Need Keys for Honda Dream 305
Please allow us to know the numbers that are on the SWITCH and the FORK LOCK. ........lm
crl1 wrote:I recently purchased two 305 projects without keys. I've heard there may be a way to get some ID numbers from the key switch and then contact a Honda dealer to see if they still have any of these old keys. I'm not sure of the process or whom to contact by way of a dealership. Any info is appreciated.
keys for 305 dream
Thanks for all those who have posted to this so far. I looked at both bikes last night and came away with the following numbers from the ignition switch facings: NA626 and NA806. Do these appear to be consistent with what I should see? If so, can I go directly to someone line "hondakeys.com" and get some made? Any help is appreciated (also thanks for the pics).
Re: keys for 305 dream
I have the NA626 with the "T" type key.
I also have that number with the square type key. ......................lm
crl1 wrote:Thanks for all those who have posted to this so far. I looked at both bikes last night and came away with the following numbers from the ignition switch facings: NA626 and NA806. Do these appear to be consistent with what I should see? If so, can I go directly to someone line "hondakeys.com" and get some made? Any help is appreciated (also thanks for the pics).
