Spoke Lacing
P.Martinez
Post by P.Martinez » Wed Jan 29, 2014 9:18 am
Thanks Ed. Will assemble with washers & without to check on differences. I suspect that the washers rotate and reduce the "stick/slip" torque when tightening the nipples. I would also believe that the distance that the spoke is seated in the nipple will be a factor (might stick out too much beyond nipple without washers).
Phil M.
Post by LOUD MOUSE » Wed Jan 29, 2014 9:52 am
Now your thinking.
Not sure I've seen a sealer in the area but ??
The rubber tire flap seems to seal from normal moisture. ...............lm
uote="P.Martinez"]Thanks Ed. Will assemble with washers & without to check on differences. I suspect that the washers rotate and reduce the "stick/slip" torque when tightening the nipples. I would also believe that the distance that the spoke is seated in the nipple will be a factor (might stick out too much beyond nipple without washers).
Phil M.[/quote]
