Just finished painting my bike and the only flaws were places where I did not sand bondo filler enough before starting. Had to redo those.
I sandblasted everything first.
Then prime and sand.
Next three coats two weeks apart and between each I wet sand 1200 grit.
First coat is thin, last coat if fairly heavy.
No further sanding after top coat, no clear coating, and I am happy.
I used Rustoleum high gloss enamel and bang for the buck is very high.
DIY Painting Procedure
- hondadreamca77
- hondadreamca77
Just finished painting my bike and the only flaws were Bondo filler not sanded enough. Had to redo those. I used a HVLP gun.
Three coats with two weeks between and wet sanded 1200 grit.
No further sanding after top coat and no clear coating, and I am happy.
This is my CB77 tank which I painted in my backyard using 'clear over base' paint from my local auto paint stockist.
I use small HVLP guns, start with an etch primer, then filler primer to cover the blemishes. I wet sand between coats then several coats of clear on top. The clear has not been sanded as it turned out nice without.
CB77 Tank 1 by graham.curtis, on Flickr
And some 1962 Dream parts using the same process but with cellulose.
C72 Parts - painted by graham.curtis, on Flickr
Painting a bike is great fun as it requires only patience to get a good result. I find the process quite therapeutic. No need to rush on a 50 year old bike...... :-)
- hondadreamca77
chrisnoel
Ditto, Beautiful work.
Very nice work indeed! I was thinking of going over my rattle can work with the clear process suggested earlier but I went with gloss black. Might wait till it gets worn now and start over with blue.
