weird oil leak think
readyjimm
Post by readyjimm » Mon May 07, 2012 12:35 pm
when I let my honda dream 305 idle for a while, it appears that i have oil leaking from the headers/ Right piston cover. Can someone give me a little insight on this?
Thanks
OldStan
Post by OldStan » Mon May 07, 2012 1:39 pm
You might check the cam cover behind your points plate. I had a similar leak on the left side and the left cover was loose and oil was running down the fins.
63 CA78
readyjimm
Post by readyjimm » Mon May 07, 2012 1:43 pm
is there a seal or gasket there?
OldStan
Post by OldStan » Mon May 07, 2012 1:46 pm
There's a gasket behind the cover. There's also a seal in the cover keeping oil off the points.
63 CA78
