I know that Dreams usually take a 3.25 x 16 front tire size (I think the rear is 3.50 x 16). Does anyone know if a 3.00 x 16 will work? Will it have problems fitting on the rim or any other problems?
Thanks for any help!
CA77 Tires
honda carl
You can still get the correct size here (3.25-16) both front and rear
http://www.motorcyclemaniacstore.com/pr ... ycle-tires
in blackwall as far as I know.
I would rather go a size larger (3.50) than smaller and would use the same size front and rear whatever the size.
There is at least one member here who sells that size:
http://scramblercycle.mybigcommerce.com ... nda-dream/
Others have used 100/90-16 from various brands.
There are several threads with pics on dream tires if you do a search
honda carl
CA77 Tires
Thanks, Brewsky. These look like good sources for buying tires. The Shimko looks like a good deal.
I had asked my question because I had come across a person who has several new Dunlop ribbed tires that are 3.00 x 16 that I could get for cheap. So I thought maybe I could use them on my CA77s or perhaps my CA95. Maybe it wouldn't be a good idea.
Thanks.
Thanks.
