Is this the correct bulb??
I brought the old tail light bulb from my '62 Dream 305 to Advance Auto and they gave me a Sylvania 1157 which says 12.8/14V 27/8.3W Will that work?
Surly ya do have a manual with the wiring design or another bulb. ...............lm
Kigsby wrote:I tried the bulb and it lights, but when I press the brake lever, it doesn't get brighter. When I press the brake pedal, it does get brighter. Is this the way its supposed to work or is there a wire loose somewhere?
Kigsby
The brake light ( the brightening you describe) only works on the foot brake pedal. There is no brake switch for handlebar lever. What you are describing is correct operation.
I think that you are agonising far too much - just go out and ride the thing.......
