 CA77 Piston w/ Rings by Dr. Frankenstein1, on Flickr
CA77 Piston w/ Rings by Dr. Frankenstein1, on FlickrMy question is, does the chrome ring go on Top, then the duller-finished ring, and then the oil ring...? And I Assume the little waffle-looking ring goes between the two rings that can be seen on the right, 'sandwiching' the waffle part...I know the oil ring goes on the bottom, but of the other two rings, which is the Scraper, and which is the Compression ring, and what order do they go in...?
Again, I would assume Compression on the top, Scraper in the middle, and Oil on the bottom - is that right?
