Correct plugs for my Dream
casamere
Post by casamere » Sun Mar 17, 2019 12:09 pm
After rebuilding my 66 CA77 I fitted NGK D8HA but now I am reading the correct plug is D6HS,
Can someone put this to bed for me and confirm which I should be using. Thanks.
Frank
Spark plugs
Post by Frank » Sun Mar 17, 2019 1:02 pm
In my original owners manual, It says 6's
Re: Correct plugs for my Dream
Post by LOUD MOUSE » Sun Mar 17, 2019 4:07 pm
At times with these bikes we find things that work are a bit different than originally recommend.
The D8 will and does work well and is a bit easier to get. .................lm
casamere wrote:After rebuilding my 66 CA77 I fitted NGK D8HA but now I am reading the correct plug is D6HS,
casamere
Post by casamere » Sun Mar 17, 2019 4:27 pm
http://www.moto1.nz/ngk-plug-dr8hs-5123 ... ha-b-dr8hs
My thanks gentlemen and without wanting to rebuff your comments has anyone experience of these.
Post by LOUD MOUSE » Sun Mar 17, 2019 6:18 pm
From what I see of the plug they show.
If you install it "you will bend the intake valves as that pic shows a LONG THREAD PLUG!. ..............................
casamere wrote:http://www.moto1.nz/ngk-plug-dr8hs-5123 ... ha-b-dr8hs
Frank
plugs
Post by Frank » Sun Mar 17, 2019 9:46 pm
I 've used both in my dreams, I seen no difference. The 6's are a little hotter they say.
Frank
plug
Post by Frank » Sun Mar 17, 2019 9:53 pm
To be clear...I've only used D8ha and D6ha.
