Early 1963 CA77 Shipping Question
SteveAllenHonda
Post by SteveAllenHonda » Fri Aug 10, 2018 5:15 pm
Hi, I need to ship an early 1963 CA77.To prevent an "oversize" rate on UPS for the frame my ?-is the rear fender section welded at the seam or is it held together by the rear shock mount brackets? Also-the weight of the engine only? Thanks in advance.
Steve
Re: Early 1963 CA77 Shipping Question
Post by LOUD MOUSE » Fri Aug 10, 2018 6:12 pm
I think it is spot welded.
The engine is APX 130 lb. with starter.
"I THINK". ...................lm
SteveAllenHonda wrote:Hi, I need to ship an early 1963 CA77.To prevent an "oversize" rate on UPS for the frame my ?-is the rear fender section welded at the seam or is it held together by the rear shock mount brackets? Also-the weight of the engine only? Thanks in advance.
Steve
jkv357
Post by jkv357 » Sat Aug 11, 2018 8:21 am
Steve
Yes. It does not unbolt.
SteveAllenHonda
Post by SteveAllenHonda » Sat Aug 11, 2018 4:54 pm
LOUD MOUSE wrote:I think it is spot welded.
Steve
Thank You for the information.
Steve
Post by LOUD MOUSE » Mon Aug 13, 2018 10:38 am
You are welcome Steve. ....................lm
Steve
Steve
