ca77 clutch
bluejean
ca77 clutch
Post by bluejean » Wed Aug 08, 2018 2:59 pm
I have a 1965 Honda ca77, I am looking to install the clutch disks, plates, and spring clips. I took it apart awhile back. So far you start with the thick plate bevel side in, disk, plate, disk plate, disk ,plate, disk, plate, disk, and cover. Where do the clips go and how many?
Re: ca77 clutch
Post by LOUD MOUSE » Fri Aug 10, 2018 6:15 pm
If your question is about the wires they install after the thick plate, friction then steel then wire. ....................lm
bluejean wrote:I have a 1965 Honda ca77, I am looking to install the clutch disks, plates, and spring clips. I took it apart awhile back. So far you start with the thick plate bevel side in, disk, plate, disk plate, disk ,plate, disk, plate, disk, and cover. Where do the clips go and how many?
bluejean
Post by bluejean » Sun Aug 12, 2018 7:23 pm
one after the other? Three or two clips?
Post by LOUD MOUSE » Mon Aug 13, 2018 1:11 pm
If you have a 65 there should only be 2 slots in the center hub. ................lm
bluejean wrote:one after the other? Three or two clips?
