clutch will not disengage
morleyj
Post by morleyj » Fri Jun 01, 2018 4:47 pm
Hello folks. I am helping a friend make his ca77 roadworthy. Got the engine running and the carb dialed in. Right now I am stuck on the clutch not disengaging. The cable seems fine and is working the release mechanism but I can't get the clutch to disengage at all. I haven't done any barn restos that were this old and I am hoping that I won't have to pull the cover and manually clean the clutch. Any pointers from the pros out there?
Post by Seadog » Fri Jun 01, 2018 7:13 pm
Sorry Morley, pull the cover and clean the clutch plates. They stick.
OC305
Post by OC305 » Sat Jun 02, 2018 8:48 pm
My Ca 77 does the same thing get the motor running and warmed up then push it in neutral to about 2 mph then shift into first gear while keeping the clutch lever pulled in then shift to second and lug it down then pour the coals to it a few times, it should free up if not repeat. It will do this every time it sets awhile. I rode mine last season a hunderd miles one day and it has been fine since Pat
