Rear wheel removal
casamere
Rear wheel removal
Post by casamere » Thu Feb 22, 2018 2:32 pm
How easy is it on the Ca77? Does the rear cog stay in place on the chain or do I have to take chain guard off. Fitting new tires.
Post by G-Man » Thu Feb 22, 2018 2:54 pm
From memory, the sprocket stays in place. Pull out the spindle. Drop the spacer next to the brake plate. Pull of fthe brake plate (torque arm & brake actuating rod, too) and just pull the wheel off the cush drive.
casamere
Post by casamere » Thu Feb 22, 2018 5:01 pm
G-Man wrote:From memory, the sprocket stays in place. Pull out the spindle. Drop the spacer next to the brake plate. Pull of fthe brake plate (torque arm & brake actuating rod, too) and just pull the wheel off the cush drive.
Thanks G-Man will give that a try.
Geoff Hastings
Post by Geoff Hastings » Fri Feb 23, 2018 8:42 am
Only thing I would add to G mans explanation is to back off the brake adjuster slightly, this helps the brake plate wriggle out of the drum easier.
casamere
Post by casamere » Fri Feb 23, 2018 9:46 am
Cheers Geoff,
