Air Pump Lock Keys
cadman
Air Pump Lock Keys
Post by cadman » Fri Oct 20, 2017 12:19 pm
I have access to new keys for the Air Pump Lock - If you need any let me know.
Re: Air Pump Lock Keys
Post by G-Man » Fri Oct 20, 2017 1:18 pm
Are they blanks or do you have numbered replacements?
cadman wrote:I have access to new keys for the Air Pump Lock - If you need any let me know.
Jims65CA77
Post by Jims65CA77 » Fri Oct 20, 2017 2:37 pm
Air pump lock?? Can I ask what that is? I take it that it has something to do with the hand pump for the tires??
Jim
Post by Seadog » Fri Oct 20, 2017 3:37 pm
A tire air pump was standard equipment until, I believe, about 1963. It was mounted horizontally on the left side of the frame, below the bottom edge of the seat between 2 brackets. I think you'll find the mounting holes for the brackets on the frames of later models. One bracket had a lock in it to avoid theft of the pump. The pumps are scarce. One on ebay sold a week or so ago for $475. I see the mounting brackets around occasionally (also costly), but I've never seen the lock. Maybe someone here on the forum would post some photos.
Post by G-Man » Fri Oct 20, 2017 4:01 pm
Here you go - this is just the lock & key.....
Jims65CA77
Post by Jims65CA77 » Fri Oct 20, 2017 4:20 pm
Thanks, I get it now! That makes sense because the pumps would be easy to... take off. I used to have a 1965 Yamaha YDS-3 (250cc) that had an air pump under the gas tank. It did NOT have a lock. I DID save the air pump... but sorry to say the Yamaha is gone.
Jim
Post by Seadog » Fri Oct 20, 2017 4:21 pm
Ah, so that’s what it looks like. Thanks, G. There’s a pump with brackets and, apparently, with lock for sale on eBay right now. 6 bids with the current bid at 125.50
https://www.ebay.com/itm/Honda-Original ... D8&vxp=mtr
