Electronic Ignition Pops
Dr. Frankenstein
Post by Dr. Frankenstein » Wed Apr 26, 2017 3:26 pm
Well, I knew I'd be back...:)
This is kind of a continuation of the 'Carb Won't Fill' post, which I solved after I replaced the carb needles etc with a new kit, the right one: Keyster KH-1316.
So I now have fuel flow to the carb, but I also put on a Tytronic electronic ignition in the hopes it would improve performance.
Timing is set to the "F" mark; I filled up the carb, put a fresh battery on her and cranked her over, but no joy. Very strong crank, nice compression (125 per cylinder), but NO SPARK! RRRrrrrrrr........
But here's the thing: yes, I pulled the plugs and tested them against head, and saw no spark;
Now I know the Dreams have a wonky ignition switch, with, like, 5 different settings...I clicked through the settings - I brought it up to the top one - and it backfired!
Did it again - cranked it over, no luck, clicked through the ignition settings, and BLAM! The right muffler shot about 5 inches of flame out of and made me jump.
Carburetor is set to 1 1/4 turns out on the fuel screw, and the same on the airscrew, which is the kind that does NOT get an o-ring - at least from everything I've read here...
It has a new 12-volt coil...the Radio Shack rectifier mod...new spark wires and caps...???
I'm going to go back over the ignition settings on the crank, to make sure I have it set right - but the Dream is a wasted spark system, right? Only one cylinder fires at a time...? And usually the engine fires when the points just begin to open, although in this case there are no points, or condenser - just the Tytronic electronic ignition...
But the weird thing is, is Why would I get a backfire with no spark, especially just by clicking through the ignition settings? ( I also hope I didn't hurt the engine...sound like a shotgun!)
Backfiring is a sign of a lean condition...should I open up the fuel screw a bit more? Close it? And what good will that do me if I can't See a decent spark? Is there one there? And Why would it "fire" when I clicked through the ignition switch?
Ya gotta love old bikes...ya gotta....
Re: Electronic Ignition Pops
Post by LOUD MOUSE » Wed Apr 26, 2017 5:39 pm
So far have you checked the unit for 12 volts in the position you try to start the engine?. ................lm
Dr. Frankenstein wrote:Well, I knew I'd be back...:)
Dr. Frankenstein
Post by Dr. Frankenstein » Wed Apr 26, 2017 6:57 pm
Checked the unit? You mean the coil? Or do you mean am I getting 12 volts to the electronic ignition?
No, neither - not yet, anyway; but good point... how would I do that - just check across the connectors from the wiring harness to the elec. ignition wires, or from the coil?
Dr. Frankenstein
Post by Dr. Frankenstein » Wed Apr 26, 2017 6:59 pm
...and if that comes up no good, what then? Or indeed, if it DOES come up positive, what does that mean? Spark wires?
Post by LOUD MOUSE » Wed Apr 26, 2017 7:00 pm
If you have a schematic showing were the wires go use it and check battery to the new part. ......................lm
Dr. Frankenstein wrote:Checked the unit? You mean the coil? Or do you mean am I getting 12 volts to the electronic ignition?
danielzink
Post by danielzink » Wed Apr 26, 2017 8:33 pm
I got no spark either from my electronic ignition (eBay)....
I know it doesn't help....but the thing gave me fits...
I cleaned my points...reinstalled them...and went on a ride last Saturday....
Dan
Post by LOUD MOUSE » Wed Apr 26, 2017 11:11 pm
Different item here. ................lm
danielzink wrote:I got no spark either from my electronic ignition (eBay)....
Dan
