Broken Speedometer Needle Shaft/Post
stepper
Post by stepper » Sun Jul 03, 2016 10:33 am
As I had mentioned in a previous post (and in the classifieds), I had broken my speedometer needle shaft while trying to pry it off for disassembly.
I have posted in the classifieds and am scouring Ebay and Craigslist for a replacement but I was wondering if anybody knows if there is any other bike (possibly the baby dream?) that I can salvage a replacement shaft from?
Thanks for any replies.
JV
Post by G-Man » Tue Jul 12, 2016 1:04 am
There are a lot of basic similarities between speedos / tachos of all of the 'family' of 305 bikes. It may be possible to transplant (if you are very careful) the shaft out of anything you can find.
This is a CL77 part....
stepper
Post by stepper » Tue Jul 12, 2016 9:21 am
Thanks G,
The speedo you show actually has a different set of worm and drive gears and the shaftlooks to be shorter than mine.
I ended up buying a broken unit off of Ebay for parts.
The unit I bought was an identical looking Nippon Seiki unit that used philips head screws on the face and back instead of the flat head screws on mine. I planned on scavenging just the needle and shaft but I found that there doesn't seem to be an easy way of removing the shaft from the inner cup. So I decided to just fit the entire cup and shaft assembly onto my unit. But I then found that the two units used different cup sizes and a slightly different frame design as well!
In the end I pieced together a good mix of both units using the broken speedo's frame, cups, shaft and needle along with my old speedometers worm and drive gears, digit assembly, face and housing. I buttoned it all up with silicon glue.
I am quite proud to say that the unit now looks and functions great!
Post by G-Man » Tue Jul 12, 2016 11:43 am
Stepper
That's the way to do it. There's always a way out of these problems which just costs a bit of time and ingenuity.
Looks like you have a result and some useful education to go with it.
