                    Electrical Short - CA77 1964
				Maximum Carnage
After extensive work on it and hooking up the battery, somewhere there is a short.
When I purchased the motorcycle it started with just the kick starter, the battery didn't seem to have enough juice to to turn the starter. The wiring was a bit shot, electrical tape wrapped around wires, I cleaned it up but seems I missed something.
The starter kicks in on every position but off, please ask away.
Re: Electrical Short - CA77 1964
Check the wire on the bars at the starter button. ...................lm
						Maximum Carnage wrote:After extensive work on it and hooking up the battery, somewhere there is a short.
				Maximum Carnage
That makes sense, especially being that I did swap out all the cables. I'll try that this afternoon and report back....
						LOUD MOUSE wrote:Check the wire on the bars at the starter button. ...................lm
				Maximum Carnage
				Maximum Carnage
Coming from the breather hose, been searching but not finding exactly what it could be... Any advise would be appreciated.
						LOUD MOUSE wrote:Where is the oil coming from?. ...............lm
Maximum Carnage wrote:Yes, that was the issue. The starter button cable was pealed back from when I installed the throttle cable.
Got it running now sputtering oil....
Call me when you are at the bike.  830-895-0654. ........lm
						Maximum Carnage wrote:Coming from the breather hose, been searching but not finding exactly what it could be... Any advise would be appreciated.
