300 Dream plugs
ggarton
300 Dream plugs
Post by ggarton » Sun Oct 12, 2014 10:14 pm
Any reason one plug fowls, and the other does not ??
rrietman
Post by rrietman » Sun Oct 12, 2014 11:45 pm
compression
Randy
ggarton
Post by ggarton » Mon Oct 13, 2014 9:25 pm
Thanks, I'll do a check.
ggarton
Post by ggarton » Mon Oct 27, 2014 2:31 pm
125 psi both, still have one plug that keeps going bad ?????
48lesco
Post by 48lesco » Mon Oct 27, 2014 8:14 pm
Oil-fouled (black and shiny), or carbon (flat black)? If oil, it could be a worn intake valve guide on that side. If carbon-fouled, I would suspect ignition since compression is OK. Swap the plugs and see if the problem follows the plug. Then swap the caps, or just install new ones. D6HA plugs are recommended and new NGK caps are cheap.
-48
ggarton
Post by ggarton » Mon Oct 27, 2014 10:28 pm
I replaced the coil, wires, caps etc. I have 2 part bikes. If this does not work, I will get new caps. Is there any way to install new wires at coil ??
ggarton
Post by ggarton » Mon Oct 27, 2014 10:30 pm
Sorry, it is flat black. That is why I was thinking coil.
