Where do I find the Vin# that is stamped into the frame?
The number on the engine is CA77E-1017975, but I cannot find any numbers on the frame. Where should they be located?
- Waveblaster
- Jims65CA77
Also, look at the bottom of the spring on the brake light. Mine is just behind that. They are hard to find. See this older post where I added photos.
http://www.honda305.com/forums/cannot-f ... 33515.html
Jim
- Jims65CA77
Most states use the FRAME number whether it is easy to see/find or not.
Engines are easy to swap and frames are most of the bike. .......lm
WvDream wrote:Thanks Jim, but I had found it with Waveblasters info. But those pics will come in handy for others. They sure did hide that serial #. I would say that the numbers on the engine is what is used for the vin # since it is much more visible.
