key issue
froggy
key issue
Post by froggy » Thu Aug 14, 2014 11:38 pm
Hi all,
I received the key I needed to be able to lock the front fork of my 1962 dream 305 (CA77) but despite the correct key #, it is tough to fit it in and impossible to turn it to lock the fork. I'd like to take the barrel out to check for rust and clean/lubricate the pins and springs.
I am unsure how to get the barrel out: any idea?
thank you
cheers
Ivan
Post by G-Man » Fri Aug 15, 2014 10:57 am
Remove the screw (or rivet) above the lock. The barrel will slide right out.
ImageKey Number by graham.curtis, on Flickr
froggy
Post by froggy » Sat Aug 16, 2014 12:59 pm
hi Gman.
thank you for the reply.
I had done just that and the barrel would not come out and therefore the reason of my question. I thought there might be a trick to it. There a little groove to the top between the barrel and the frame: maybe one needed to push on something inside there.
Cheers
Post by G-Man » Sat Aug 16, 2014 2:05 pm
Hi
If you drop the front fork you can usually tap it out from inside of the head stock.
