                    question on a rear wheel
will a rear wheel off a 1966 Honda 305 Dream  work on a 1961 Honda 305 Dream
						Early versus late wheel
I am pretty sure the same swingarm, spacer and axle were used throughout production, so I think the wheels should interchange.
I think you will have to use a matching brake plate for the wheel you use. The hubs and brake plates did change.
The sleeve that the axle goes through on the sprocket side did change, but I am not sure what the difference is.
You should do a thorough search of this site to make sure no one tired this before and it ended up not working.
Front wheel issues
Linemup,  What issues did you run into?
