Having trouble reinstalling Rt side engine Casing and clutch......How do line up the clutch adjuster when re-installing the clutch cable . Is there a trick to where the adjuster (where the cable hooks inside the case) goes or how it hooks to the shaft inside the case..... Need help
Thanks in advance
Need help with Right Side Engine Casing Installation !!!!!!
MississippiDreamin
