How does the battery get charged on a Dream?
styxjr
Post by styxjr » Sun Sep 23, 2012 9:22 pm
Hi, I have a dumb question ... does the Dream have a battery charging system? I have a '66 Dream with a 12N9-3A Interstate Cycle-Tron battery that I have to take out and charge every two weeks approximately. My thinking is that these bikes did not have a battery charging system on them? I've seen posts that mention a "tender". Is that something that acts like a battery charger?
Hahnda
Post by Hahnda » Sun Sep 23, 2012 9:27 pm
Yes they have a charging system. If running with your headlight on all the time it is quite possible that the charging system is not able to keep up. A battery tender is a low amp battery charger/maintainer that many people will use when the bike is not in use.
styxjr
Thanks
Post by styxjr » Sun Sep 23, 2012 9:51 pm
Thanks Kevin,
After further reading I've also learned that a new rectifier might help me, and that the middle position on the dimmer switch is supposed to charge the battery. I have to learn to read more first, then ask.
Thanks again,
- styxjr
Tango911
Post by Tango911 » Mon Sep 24, 2012 6:17 am
if you keep a trickle charger on the battery that will help too. since i only ride mine every two weeks or so, i put a charger on it the day before just to make sure she's fully charged. you can learn how to check your charging system with a meter also.
65 Sears Puch 250
69 Dream 305
74 Kawi H1
78 CB750 SS
pknopp
Post by pknopp » Mon Sep 24, 2012 7:12 pm
Mine has remained charged even through the winter. I did ride it on occasion (40 plus days). I've been lucky though as old Honda's have never been known for their charging systems.
mschehen
New rectifier
Post by mschehen » Mon Sep 24, 2012 9:16 pm
I bought the rectifier that the guy from Portland sells on ebay. Shipped it was around $30 and so far has worked well. I ride once or twice a week during the summer and even without using a tender it always starts. I do use a battery tender during the winter and have also switched over to one of the sealed batteries somebody else mentioned on the forum a month or so ago. I also got this on ebay and it was around $25 shipped, about half what I have paid for batteries for my bikes in the past. Hope this helps.
Hahnda
Post by Hahnda » Mon Sep 24, 2012 9:27 pm
If you want a new rectifier that looks like an original but works with more modern technology.
http://www.olypen.com/retro/31700-259-030.htm
Then there is always the $3 Radio Shack rectifier.
http://physiology.usouthal.edu/restore/diode/diode.html
The one from Oregon Motorcycle Parts is a similar solution but its ready to install.
http://oregonmotorcycleparts.com/rectifiers.html
