Carb adjustment question?????????
sky1haze
Post by sky1haze » Wed Sep 15, 2010 9:51 pm
I feel a bit silly asking, but can someone explain to me which screw is the fuel mixture adjustment on a carb for a 1966 dream???? Or even a quick tutotial on how to do a quick adjust?????????
I will be more than grateful! Thanks.
-j-
sky1haze
Post by sky1haze » Wed Sep 15, 2010 9:52 pm
I meant tutorial!
brewsky
Post by brewsky » Thu Sep 16, 2010 5:10 am
As you look at the screws, it is the one on the left, closest to the engine.
Turn it in all the way till it seats (gently) and back it out 1 1/2 turns.
It controls the amount of air in the idle circuit, so the more you turn it out, the leaner it gets.
You can tweak it from there with the engine warmed up, choke off, by turning in or out 1/4 turn at a time and listen for engine to speed up.
When you find the position that gives max RPM, reverse your last move 1/4 turn.
sky1haze
Post by sky1haze » Thu Sep 16, 2010 8:31 am
That is great, I will give that a shot today! Always appreciated, Evereyone is great on these forums!
Anyone else have any additional tips?
Cheers,
-j-
Post by LOUD MOUSE » Thu Sep 16, 2010 9:22 am
Ya may find it necessary to adjust the slide screw also. ............lm
sky1haze wrote:That is great, I will give that a shot today! Always appreciated, Evereyone is great on these forums!
Cheers,
-j-
Tango911
Post by Tango911 » Thu Sep 16, 2010 9:30 am
kudos to the experts! aint this site great.
65 Sears Puch 250
69 Dream 305
74 Kawi H1
78 CB750 SS
sky1haze
Post by sky1haze » Fri Oct 22, 2010 12:30 pm
I just recently learned from reading the original hand book that it is the screw further from the engine in which you want to screw in till it is seated then out about 1 1/8 turns, then the screw closer to the engine to control the idle.......This whole time I was racking my brain, taking my carb in and out about 10 plus times trying to get the perfect settings....atleast 18 plugs etc......All in all it was the wrorng screws I was setting.....I went for my first normal ride today!!!!!!!!
-joel-
_______________________________________
1966 CA77
