Perplexed
Eljeef
Perplexed
Post by Eljeef » Fri Sep 10, 2010 4:33 pm
A quick question; Is it possible for the timing on a Dream to be out by 180 degrees? Thanks, Jeff.
1964-C77 305 Dream
2002 BMW R1150GS
Post by davomoto » Fri Sep 10, 2010 8:06 pm
Yes, for a quick answer.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
Eljeef
Post by Eljeef » Fri Sep 10, 2010 11:01 pm
Thank you. Now I can move on. My bike is behaving like it is 180 out and only since I changed my points and "adjusted" everything. I think I am the culprit. :)
1964-C77 305 Dream
2002 BMW R1150GS
paperslammer
Post by paperslammer » Sat Sep 11, 2010 12:35 am
How will it behave if it is 180 deg off?
'64 CA77 305 Dream
Eljeef
Post by Eljeef » Sat Sep 11, 2010 1:02 am
paperslammer wrote:How will it behave if it is 180 deg off?
Well, it is turning over forever without a hint of starting. It has a fuel supply, good battery, carb seems to be fine, good spark plugs and wires, coil is good. My understanding is that if it is 180 out then it is firing a spark into the chamber on the exhaust stroke when there is no compressed air/fuel to ignite instead of throwing a spark on the compression stroke, thus igniting the fuel/air mixture with the resultant explosion forcing the pistons to move and etc, etc. I just have to figure out how to check and adjust the problem. Cheers.
1964-C77 305 Dream
2002 BMW R1150GS
brewsky
Post by brewsky » Sat Sep 11, 2010 4:01 am
A Dream is supposed to fire on the exhaust stroke (Type II) engine.
Since the pistons rise and fall together, and there is only one set of points, it is called a "wasted spark" system, and the plugs fire on both compression and exhaust.
Have you checked the timing?
Post by davomoto » Sat Sep 11, 2010 11:40 am
Jeff, I don't think you can alter the timing 180 degrees by changing the points. Does the bike have spark? If not, make sure you attached the wire to the points correctly, it must be insulated from the points base with the plastic washers and collar.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
