LEAD ADDITIVE
ROBM50
LEAD ADDITIVE
Post by ROBM50 » Tue Aug 19, 2008 10:41 pm
HEY GUYS! I OWN A 1966 CA77 DREAM AND WAS WONDERING IF IT WAS NECESSARY TO ADD A LEAD ADDITVE TO FUEL SINCE THESE ENGINES WERE ENGINEERED DURING THE LEADED GAS ERA OF THE SIXTIES? SOMEONE SAID THAT IT WOULD HELP WITH THE LUBRICATION OF THE VALVES. WHAT DO YOU GUYS THINK?
ROB
Re: LEAD ADDITIVE
Post by LOUD MOUSE » Tue Aug 19, 2008 10:47 pm
Use the gas supplied today. I don't use any lead substatute. .............lm
ROBM50 wrote:HEY GUYS! I OWN A 1966 CA77 DREAM AND WAS WONDERING IF IT WAS NECESSARY TO ADD A LEAD ADDITVE TO FUEL SINCE THESE ENGINES WERE ENGINEERED DURING THE LEADED GAS ERA OF THE SIXTIES? SOMEONE SAID THAT IT WOULD HELP WITH THE LUBRICATION OF THE VALVES. WHAT DO YOU GUYS THINK?
ROB
RIDE IT DON'T HIDE IT!
albano.martins
Post by albano.martins » Wed Aug 20, 2008 2:07 pm
Hi ROBM50 !
I use gas supplied today too, like LOUD MOUSE.
I don't know if will help with the lubrification of the valves or keep the carburators preserved.
My bike runs well with the gas supplied today.
If anyone knows the answer i woul like to know too.
Thanks ROBM50 and LOUD MOUSE,
Albano Martins
lrutt
Post by lrutt » Tue Aug 26, 2008 7:31 pm
I keep a standard mix for all my old bikes, brit and asian. the mix is made up of 93 oct gas, lead additive, stabil, and 50:1 2 stroke oil.
Works great on all bikes. the 2 stroke oils now days don't smoke so the oil keeps the carbs, pipes, and tank coated just enough to help prevent rusting etc. Keeps the carb slides free as well. I have several classic bikes and they all don't get run but maybe once a month so it really helps ot keep things working well. That and I always drain the carbs after I run the bikes to keep things form gumming up. I just don't have problems any more since I've started this routine years ago.
mangajunky
Post by mangajunky » Wed Aug 27, 2008 2:51 pm
lrutt wrote:I keep a standard mix for all my old bikes, brit and asian. the mix is made up of 93 oct gas, lead additive, stabil, and 50:1 2 stroke oil.
I never would have thought to use 2-stroke in a 4-stroke's fuel. Have you put a lot of miles on your bikes with this regimen? I frequently take 100+ mile weekend trips.
-Franky
'79 Vespa ET3
'73 Lambretta Jet 200
'66 Honda Dream 305
allthumbs
Post by allthumbs » Mon Sep 08, 2008 6:15 pm
couple of things Irutt,
do you find that the mixture becomes too rich in any of your bikes, requiring an adjustment of the main needles?
What would happen if you did't use this mix after using it? if on a trip and you don't have it?
