Dr. Frankenstein wrote:What do you mean by 'clamp down on the head'?? Where?
Cam Chain Length
Dr. Frankenstein
That could be, but I'm confused(having never done this before):
"clamp down on the head at this point to join the chain ends on the cam sprocket. Use a bunch of washers or a socket wrench etc as spacers on the 4 inner head studs to draw it down temporarily."
Please correct me if I'm wrong, but the cam sprocket is inline with the camshaft; the camshaft is solidly in line with the cam bearings, which are embedded Very firmly in the head, which (as far as I know) is not flexible at all.
It seems to me (again, not having done this before), that drawing down on the 4 inner head studs (the 4 of the 8 that the head mounts on, right?) is only going to bend the studs, and not make the cam sprocket sink any lower. My head (no pun intended :) is solidly mounted against each other, and the engine block, and is essentially ready to have the lid put on...do I need to lift the cylinder head, or...??
This compresses the head to the cylinder to the case. ...........lm
Dr. Frankenstein wrote:That could be, but I'm confused(having never done this before):
Dr. Frankenstein
Dr. Frankenstein
He called you Surly, he saves Shirley for other things...
The idea on the cam chain is to compress the base and head gaskets slightly to give the cam chain a little more slack. The spacers temporarily take up the thickness of the top cover and gaskets. With a used cam chain, you shouldn't need much to get the ends of the chain together. Let us know how you make out.
