Motor "cap" removal on bike?
hotrodhendrix
Post by hotrodhendrix » Mon Apr 27, 2015 2:14 pm
Very good note! Thanks for added that.
conbs
Gasket
Post by conbs » Fri May 08, 2015 10:30 pm
When you checked compression did you have the throttle open?
Did you put the aluminum plate and the other gasket (installed with the hole the right direction) under the head cover?
hotrodhendrix
Post by hotrodhendrix » Wed Jun 03, 2015 4:06 pm
Sorry been off the site for a bit. Yes to all the above. Motor ended up needing to be bored .75 over and exhaust valves were bad. Should have all the new jazz in Monday for the machine so hopefully get to put it back together weekend after next.
~James
