1966 Honda 305 Firing Problems HELP !!!!!!!!
cadman
Post by cadman » Sun Apr 21, 2013 7:26 pm
Just read your last post - It's fuel - not enough gas getting to the carb - fuel line plugged somewhere.
MississippiDreamin
Post by MississippiDreamin » Sun Apr 21, 2013 9:12 pm
why would it be loosing power at the points ????? We check there when it quits and no power.... Also, all fuel lines are new.....
paperslammer
Choke
Post by paperslammer » Sun Apr 21, 2013 9:51 pm
I had this problem for a while. The plugs were getting crazy black too. I figured out that I was running the choke on the carburator with the handle up (close to the seat). Once the engine has started and warmed up, it should be in the down position (away from the seat). Maybe that is the problem?
'64 CA77 305 Dream
conbs
Power at points
Post by conbs » Sun Apr 21, 2013 10:45 pm
Lots of opinions here and they are all good things to check.
If you lose power to the points you lose spark as well. Confirm that the points are not closed when you are "losing power". Turning the crank a little should confirm that you have in deed lost power. If so, somewhere in the mix the power has to come back on at the coil again for it to start. Have you confirmed when that happens? Does your horn work when you lose power to the coil? If not that will be an easy way to confirm when your power returns. When the horn starts working the coil should have power. If all of this is what is actually happening, then it sounds like you need to focus on your key switch, in a connection in the black wire in the harness or in the black wire itself.
When the power goes out in the black wire do you still have power in the red wire coming from the fuse to the key switch?
I hope you get it solved soon.
MississippiDreamin
Post by MississippiDreamin » Mon Apr 22, 2013 7:21 am
Horn works all the time.....Will check the other wires for power....
cadman
Post by cadman » Mon Apr 22, 2013 8:23 am
There is not "power" to the points - they just complete a ground to fire the coil. If you just run a hot jumper (+12VDC) to the positive side of the coil you bypass all other electrical "stuff". If it does not run this way it is either coil or points or fuel.
I still think it is fuel - You start with a full float bowl - there is an obstruction somewhere in fuel delivery - it runs until the float bowl is empty. It stops, you wait, during this time fuel is trickling into the carb again. The float bowl is full again and the problem repeats. It could be the float set way too low - something restricting the flow at the carb or tank. You should have a drain screw in the bottom of the float bowl, Remove it and check the flow.
MississippiDreamin
Post by MississippiDreamin » Mon Apr 22, 2013 11:22 am
I will check all of that ...... Thanks for the help and I will let y'all know what the outcome is....
