installing a new chain on 66 honda dream ca77
Post by LOUD MOUSE » Wed Apr 29, 2009 8:00 am
NO!! ..............LM
LTthisFire wrote:let me clarify, Is there a way to do it without taking the case off?
clarenceada
Post by clarenceada » Wed Apr 29, 2009 4:35 pm
Do you mean the crankCASE cover or the chain CASE? You can do it with the crankcase on but you do have to have the chain case off then stuff the chain over the sprocket and with a coat hanger wire you can grab the chain and pull it around the sprocket. It helps to have the back of the bike way up in the air so you can see down the chain without standing on our head. The chain case is bolted to the swing arm. Of course LM is right, it's easier to pop off the crankcase cover, but if you do make sure you use an impact driver on the crankcase screws.
Clarence
Post by LOUD MOUSE » Wed Apr 29, 2009 8:21 pm
I ment the chain guard cover. .........lm
clarenceada wrote:Do you mean the crankCASE cover or the chain CASE? You can do it with the crankcase on but you do have to have the chain case off then stuff the chain over the sprocket and with a coat hanger wire you can grab the chain and pull it around the sprocket. It helps to have the back of the bike way up in the air so you can see down the chain without standing on our head. The chain case is bolted to the swing arm. Of course LM is right, it's easier to pop off the crankcase cover, but if you do make sure you use an impact driver on the crankcase screws.
Clarence
clarenceada
Post by clarenceada » Thu Apr 30, 2009 12:04 am
Sorry LM, as my Sargent in basic told me to never assume anything as it makes an ass-----of u-----me.
Clarence
