air outlets
mike69
tubes
Post by mike69 » Tue Jan 27, 2009 9:03 pm
The crankcase vent for these engines is the rubber hose on the top center of the motor.Take Loudmouses advice on this one.
I sure would like to see a cutaway of the engine just to see where those vent tubes lead to though.
Re: tubes
Post by LOUD MOUSE » Tue Jan 27, 2009 9:41 pm
The intake valve guide has a shallow/narrow groove cut around the (apx) middle of the outside and 4 holes drilled from the groove to the center (valve stem) area of the guide and the head has a couple of straight line holes drilled (one hole capped) from the guide location then to the point of the head where the vent tubes for the hose to the air cleaner attaches. Was to remove moisture from the intake valve. As there isn't much vacuum at the air filter to draw/suck the air/moisture away it was a production item that was dropped. ........lm
mike69 wrote:The crankcase vent for these engines is the rubber hose on the top center of the motor.Take Loudmouses advice on this one.
RIDE IT DON'T HIDE IT!
mike69
vents
Post by mike69 » Wed Jan 28, 2009 7:34 am
Thanks LM. Thanks for the education on this! I've wondered about that since I bought my first Dream 6 years ago.
Maybe this should be a "sticky"?
Mike
mike69
air outlet
Post by mike69 » Wed Jan 28, 2009 7:35 am
removed
mike69
vents
Post by mike69 » Wed Jan 28, 2009 7:36 am
removed
66 Dream
78 Goldwing
mike69
venttubes
Post by mike69 » Wed Jan 28, 2009 7:38 am
removed
66 Dream
78 Goldwing
mike69
tubes
Post by mike69 » Wed Jan 28, 2009 7:43 am
removed
66 Dream
78 Goldwing
