Big night tonight...
Sascha
Post by Sascha » Mon Dec 20, 2010 10:28 am
Hey Cyc,
Agreed - What should I use to lube the throttle cable? suggestions?
-Sascha
cyclon36 wrote:It's hard to tell without pipes on, but I think your idle might be a bit high. Have you dropped your sliders down all the way? Also, might want to lube up your throttle cable as good measure. Not sure if that spike in RPM is a sticky throttle cable, slide, or whatever but best to cover all bases.
cyclon36
Post by cyclon36 » Mon Dec 20, 2010 11:01 am
Sascha wrote:Hey Cyc,
-Sascha
Use a spray lubricant with one of those straws. Something thin enough that will work it's way down like liquid wrench or equivalent. Others on here might have a preference that works best. Then, just disconnect the cable at the lever and start loading it from the top. Keep the cable tied up high to allow the lube to drain down towards the bottom. After an hour or so, add another squirt or two, connect the cable, and work your throttle to help lube it up.
Check the carb adjust section and go through the steps from beginning to end for good measure as well.
brewsky
Post by brewsky » Mon Dec 20, 2010 12:04 pm
Theres a detailed discussion of cable lube choices here at the end of this thread:
http://www.honda305.com/forums/viewtopi ... c&start=30
Sascha
Post by Sascha » Mon Dec 20, 2010 3:18 pm
Can I use some good ol' WD40?
-Sascha
brewsky wrote:Theres a detailed discussion of cable lube choices here at the end of this thread:
Dgormley
Post by Dgormley » Mon Dec 20, 2010 3:49 pm
Sasha, yup.
Sascha
Post by Sascha » Thu Dec 23, 2010 9:16 am
Nice - I scored a can of WD40 last night... Going to try to feed lube into the lines some time next week or so... depends on when I can get the time. I will shoot another video once they are lubed to see if its still happening...
-Sascha
Dgormley wrote:Sasha, yup.
