Post
by Dr. Frankenstein » Fri Apr 28, 2017 5:51 am
LM, I checked the switch and the coil - I have 12.27 volts at the switch, but I'm not sure how to check the coil for voltage.
The battery is fairly new - an AGM sealed battery I got last year, charged and kept on a BatteryTender 12-volt charger. The battery tested a little over 13 volts when I checked it.
The new aftermarket coil I had on there measured 1.8 ohms across the leads/wires going into the coil, and the old OEM coil that I thought was dead measured 4.8 ohms across the leads.
Thinking the new aftermarket coil wasn't producing enough "oomph" to create a spark, I took off the new aftermarket coil and replaced it with the old one and tried again, but still no spark.
I am using 7mm copper core solid spark wires from the coil to the plugs.
I have NGK 5 ohm resistor caps on the spark wires, and trimmed the wire slightly to make sure I had positive contact with the wire when I screwed them in.
Battery is fully charged, registering a little over 13 volts, actually.
I do have continuity through everything else - I tested all my connections - battery to solenoid, wire harness to the starter switch connector, the connector FROM the harness to the ignition switch, and the two leads on the electronic ignition. I have continuity through all of them.
I have continuity from the battery through the solenoid and into the harness, up to the switch where, as I said, I got 12.27 volts there.
The manual I have is no help when it comes to testing the coil - "test the coil for proper operation," is pretty much all it says - no notes on how to do it or what to look for.
This is all I know so far.
