Showing off my Dream
brewsky
Post by brewsky » Thu Jul 06, 2017 7:27 am
Looking Good!
danielzink
Post by danielzink » Thu Jul 06, 2017 10:28 am
stepper wrote:Thanks for the comments guys.
I believe the clutch cable is a CB77 mid bar cable from 4into1.com.
The brake cable is an "MC" brand cable from ebay. It is sold as a CA77 cable but has straight ends on it.
Be aware that the CB77 brake cables will not work as the ends are different.
As for the tires, yes they are Coker's.
I guess I like them well enough so far. I haven't really had the chance to push them much tho.
I hear they aren't the stickiest of tires though.
Thanks again,
JasonImage
Thanks for the info !
Is there excess cable tucked away ?
I don't have the "flat" bars. I have a set of CB400 bars waiting to go on and they have a slight rise.
Thanks again.
stepper
Post by stepper » Thu Jul 06, 2017 7:35 pm
The brake cable has quite a bit of slack.
The clutch cable on the other hand is just right for my bars.
You could probably get away with the same but it might be a bit tight.
The hardest part is getting the cables to route into the holes in the fork assembly.
There is a pretty tight bend from the perches to the holes.
