Keyster Carb Kit Common Issues - Wrong Jets and Needle
mcmig
Post by mcmig » Fri Jul 10, 2015 12:08 pm
My carb was fooling the plugs and not running on idle without Choke since it was rebuilt.
My issues was the Keyster Carb Kit, wrong Main Jet #130, Slow Jet # 40, and needle. However the Slow Jet holes were minuscule compared to the stock one.
Stock set up is Main Jet #120 Slow Jet #35
I've put back the old jets and needle and it works fine now.
I should've search about the Keyster kit on this site first, it would of save me a lot of time and troubles.
I just wanted to post a reminder of these issues with the Keyster Kit.
Re: Keyster Carb Kit Common Issues - Wrong Jets and Needle
Post by LOUD MOUSE » Fri Jul 10, 2015 2:43 pm
The Keyster kits for the CB77 carb can be used and works well with both CB77 and CL77. ............lm
mcmig wrote:My carb was fooling the plugs and not running on idle without Choke since it was rebuilt.
Post by Seadog » Fri Jul 10, 2015 3:39 pm
LM, is there a dependable carb kit for the CAs?
Post by LOUD MOUSE » Fri Jul 10, 2015 4:05 pm
Not thst I've ever seen.
Fortunately most still have the original HONDA parts so all that is need is good cleaning and a couple of rubber parts. ................lm
Seadog wrote:LM, is there a dependable carb kit for the CAs?
