CA78, sitting 10 years, recommendations?
mike in idaho
Post by mike in idaho » Sat Nov 08, 2014 8:17 pm
Unscrew the tappet covers and squirt some motor oil around to wet down the cam lobes and the valve stems.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
eamartin
Post by eamartin » Sat Nov 08, 2014 8:18 pm
Do you know why it was parked? Might give you an idea of what else should be checked.[/quote]
It was parked because my Dad felt he was no longer physically able to safely handle the bike.
eamartin
Post by eamartin » Mon Nov 10, 2014 6:11 pm
mike in idaho wrote:Unscrew the tappet covers and squirt some motor oil around to wet down the cam lobes and the valve stems.
Another good suggestion and quite easy to do. Thanks.
Angel
lrutt
Post by lrutt » Tue Nov 11, 2014 2:18 pm
eamartin wrote:
OldStan wrote:Tires over 10 years old (surely they weren't new then) should be replaced along with the tubes.
I don't intend to ride this bike. I'm prepping to sell and these are the original narrow whitewalls which I'd like to keep mounted on the bike.
wow, the original nittos. Must be low miles. Those tires must be almost 50 years old.
eamartin
Post by eamartin » Sat Nov 15, 2014 9:12 pm
[/img]
original nittos, indeed
Rear
Rear
Dream tires 001.JPG (149.93 KiB) Viewed 4217 times
Front
Front
Dream tires 002.JPG (155.29 KiB) Viewed 4217 times
dreamhog
Clutch
Post by dreamhog » Thu Nov 27, 2014 6:45 pm
It's also likely the clutch plates might be stuck together. Sometimes they can be worked free after the motor is started and warmed up. You might have to go into the left side case and free them but you might get lucky.
eamartin
clutch plates
Post by eamartin » Sun Nov 30, 2014 6:58 am
Yes. I expect to have clutch plate issues and asked about this in another thread. Since I'm prepping the bike for sale, I really want everything to be functioning properly for any potential buyers.
