Alternator/Stator
cadman
Alternator/Stator
Post by cadman » Tue Dec 11, 2012 11:42 am
I have read all the posts on the charging system. The "stator" appears to be referred to as the magneto or dynamo.
As best as I can tell is is actually an alternator with a stator and rotating magnets on the crankshaft. This would mean that it should output AC voltage to a rectifier which converts to VDC. Apparently there is no voltage regulator but supplied voltage to the battery is controlled by activating various windings in the stator (via the ignition switch) .
If so, it would seem possible to use a rectifier/regulator and run the alternator at full potential all the time. Anyone know the potential AC output of the alternator in AC volts?
Thanks - DOn
Wilf
Post by Wilf » Wed Dec 12, 2012 11:19 am
Don,
The potential output of the AC generator is primarily a factor of engine rpm's. To achieve maximum output all the time your engine rpm's would have to be about 4,000 or so all the time.
Wilf
conbs
Rectifier
Post by conbs » Wed Dec 12, 2012 11:46 am
The OEM rectifier is under the right side cover. Retrobikes in Port Angeles WA sells a modern replacement that nets an improved output and looks similar to the original. Or you can go to Radio Shack. Search this site. There is a lot of discussion on what to use and how to install it.
Not much draw (brake light periodically) until you turn on the headlight and that kicks in the higher output winding.
cadman
Post by cadman » Wed Dec 12, 2012 8:33 pm
Actually I was thinking more about the Mosfet Rectifier/Regulator - here is the site-
http://roadstercycle.com/Shindengen%20F ... %20kit.htm
This is a very efficient regulator/rectifier and would solve the charging problem on the Dream. You could run full AC voltage all the time.
However no one answered my question - What is the maximum AC voltage output from the Dream alternator
Thnaks - DOn
mike in idaho
Post by mike in idaho » Wed Dec 12, 2012 8:52 pm
You could also use a zener diode, mounted on a heat sink, to regulate the voltage. Brit bikes used them for decades.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
cadman
Post by cadman » Wed Dec 12, 2012 10:03 pm
Yeah and British bikes had really reliable electrical systems!! Remember Lucas the prince of darkness??
Wilf
Post by Wilf » Wed Dec 12, 2012 10:10 pm
Don,
Maybe the best approach here is to ask you what the charging problem on the Dream is. It would be easy enough then to understand why the MOSFET rectifier/regulator may or will not be your solution.
Wilf
