I'm in the process of freshening up a 67 dream 305.  Neither my o ring kit, nor my seal kit came with the o rings for the oil spinner or the cover. You guys have a line on some (3)?
JB
                    Oil spinner
Oil spinner o rings
Search this site.  I think someone posted SKU numbers for o-rings you can get at a hydraulic shop.
						Oil Slinger o-rings
http://www.honda305.com/forums/motors-2 ... cc-f8.html
No SKU numbers, but a path forward.
Edit: I guess that link doesn't work as I intended. Take your slinger and o-rings to a hydraulic shop. They should be able to help you.
						I got my o/r for the filter from Ohio Cycle- but with an order of other parts, he has a $20 minimum.  He also has the cover o/r's.   Beware though, there are at least two different covers.  Mine has the early which has 2 of the 57x3 mm o/r's which are available at seal suppliers, being a fairly common size (Ohio has them too.)  The later ones are larger and I think they have them as well.  A couple of different sizes show on the parts list, so the best thing to do is measure either the old o/r's or the bores and that should get you close enough to choose which ones you need. I picked up an extra set for mine since this is an area that is accessed fairly regularly.  That way if I damage a seal I don't have to wait for a replacement.
									63 CA78
