keyster float valves????
sky1haze
Post by sky1haze » Sun Sep 26, 2010 9:50 pm
Anyone have any input on The float valve that comes with the keyster rebuild kit to be used with the stock jets????????
-joel-
_______________________________________
1966 CA77
kirbb9
Post by kirbb9 » Mon Sep 27, 2010 1:59 am
I've got one in my 66, but that one is all I have dealt with ( It's working fine). Be sure and check the float level also.
I didn't use any of the jets.
Brady
66 CA77
2 GL's
ST 1300
sky1haze
Post by sky1haze » Mon Sep 27, 2010 8:31 am
Thanks Brady, Do you mind I ask what notch your needle is set at?
-joel-
1966 CA77
kirbb9
Post by kirbb9 » Mon Sep 27, 2010 3:12 pm
Sure,, needle is on the middle notch. I usually don't use the jets or needles from the kit unless mine are in unusable condition. I have heard that sometimes they are not equal to the stock parts.
Brady
66 CA77
2 GL's
ST 1300
sky1haze
input!!
Post by sky1haze » Fri Oct 08, 2010 4:03 pm
Anyone else have any input???????????
-joel-
1966 CA77
jensen
Post by jensen » Fri Oct 08, 2010 4:28 pm
I'm sorry, I use Honda jets and float valves only, can't help you out.
Re: input!!
Post by LOUD MOUSE » Fri Oct 08, 2010 4:44 pm
The KEYSTER kit for the DREAM engine has 3 usable parts.
2 are rubber and the other is the Float Valve. ............lm
sky1haze wrote:Anyone else have any input???????????
