Recieved my tires from Coker today,and all of the cosmetic flaws are in the wide white. They are there if you look carefully,but from 2 feet away,look fine.
I know some here on the site had mentioned that the speed rating on these tires was a B,and rated only to 31mph. That is not the case. The load range of the tires is a B rating,the actual speed rating of these tires is P which is 93 mph. The speed rating is located after the tire size and has 2 numbers preceding the letter,in this case,the Coker tires are stamped 48P. Look on any tire,car or bike,after the size to find the speed rating.
