								JRT68
						Post
								by JRT68 » Mon May 11, 2009 8:23 pm
			I need to replace the speedo cable on a ca78.  It looks like the front fender has to come off as the cable runs between it and the forks... in doing this, I removed the two 17mm nuts on the inside but can't get the bolts to budge.  Am I missing something?
								joeweir1
						Post
								by joeweir1 » Mon May 11, 2009 11:23 pm
			I think I was able to just loosen the shock upper bolt/nut on that side and the fender gave enough to tuck the cable along side the fender and forks.It has been awhile since I did it so I could be missing something.
								JRT68
						Post
								by JRT68 » Tue May 12, 2009 10:48 am
			I'll try that.  Is the bolt I'm framming on the upper mount for the fork spring too?  Sorry for my ignorance, I haven't dissected a Dream before and the parts diagram has the forks and suspension on different pages.
								joeweir1
						Post
								by joeweir1 » Tue May 12, 2009 9:12 pm
			"framming"??? not sure what you mean.You may want to loosen the axle nut also. This may give the forks some room to relax a smidge or maybe not.It should not be too hard to get enough room to slide the cable in there.
								JRT68
						Post
								by JRT68 » Tue May 12, 2009 9:23 pm
			After taking off the front wheel I got the fender loose and was able to get everything sorted out.  Bolts were just really stuck but PB Blaster is wonderful stuff.
								bj
						Post
								by bj » Wed May 27, 2009 4:22 pm
			Anyone know where I can find a new Speedo Cable?  I have been looking for awhile with no luck.  It would be nice to know how fast (more like, slow) I am going.
Bryan
								joeweir1
						Post
								by joeweir1 » Thu May 28, 2009 5:15 pm
			did you try Ebay or Retro bikes?
