M4x0.75 x 16mm Flat head Screws
Does anybody have a source for M4x0.75mm flat head screws? I have an ignition switch that is drilled for the old 0.75mm pitch screws. I need a couple. Thanks in advance.
Re: M4x0.75 x 16mm Flat head Screws
I had enough problem locating those JIS screws so I just bought a ISO tap and a few screws and solved the problem. ...............lm
chance wrote:Does anybody have a source for M4x0.75mm flat head screws? I have an ignition switch that is drilled for the old 0.75mm pitch screws. I need a couple. Thanks in advance.
