Brake clevis pin
Bgiles
Brake clevis pin
Post by Bgiles » Sat Feb 03, 2018 8:34 pm
Any success in removing and replacing the pin that holds the cable clevis to the rear brake shaft(CL77) and also holds the spring on the other side. Looks like it is riveted on. I'm sure I can get it off - but not sure how much damage may occur. TIA
Re: Brake clevis pin
Post by LOUD MOUSE » Sat Feb 03, 2018 8:59 pm
Some parts are not designed to be removed!. ......................lm
Bgiles wrote:Any success in removing and replacing the pin that holds the cable clevis to the rear brake shaft(CL77) and also holds the spring on the other side. Looks like it is riveted on. I'm sure I can get it off - but not sure how much damage may occur. TIA
