new to 305 scramblers splitting engine case
stripertwink
Post by stripertwink » Sun Jan 28, 2018 10:44 am
i just picked up a 1965 305 scrambler and I'm going to go through the whole bike. right now I'm trying to split the engine case to look at the transmission gears, and i can not get them apart,any tips or trick??
Re: new to 305 scramblers splitting engine case
Post by LOUD MOUSE » Sun Jan 28, 2018 11:48 am
Where do you live?. .................lm
stripertwink wrote:i just picked up a 1965 305 scrambler and I'm going to go through the whole bike. right now I'm trying to split the engine case to look at the transmission gears, and i can not get them apart,any tips or trick??
pemdoc65
Post by pemdoc65 » Sun Jan 28, 2018 1:18 pm
Make sure that you have removed the two nuts on the top of the crankcase that are located under the metal tab that the valley cover attaches to. Those get overlooked quite often.
stripertwink
thanks
Post by stripertwink » Sun Jan 28, 2018 9:25 pm
thank you pemdoc65 once i took those off it came right apart.
my next question is I'm looking to replace all the seals and i haven't found a gasket for the engine case halves?? is there one or is it just silicone? [/quote]
rrietman
Post by rrietman » Mon Jan 29, 2018 12:14 am
HondaBond
Good luck
Randy
Post by LOUD MOUSE » Mon Jan 29, 2018 1:54 am
Or YAMABOND from YAMAHA. ...............lm
rrietman wrote:HondaBond
Good luck
Randy
stripertwink
Post by stripertwink » Mon Jan 29, 2018 12:09 pm
Thank you
