Crank seal
Crank seal
I have a 65 CL 77 I bought as a barn find last year, I got it running last year then tore it down for cleaning and paint. I got running last week took it for a short ride Friday 1 mile to a friends no problem came home and oil coming out of right side engine cover. Pulled the engine cover and found the oil seal up against the rotor. Any one know what would cause this?
Age. Lip seal degradation...due to...age. Or, clogged breather tube and the aged seal just couldn't handle the pressure and gave out.
My 66 ran fine for almost a year after several years in storage. It wasn't till I pressed the motor for a sustained 60 mph for a few miles did that same seal gave out. Time to do the bottom end (seal replacements) if the rest is holding out. By the way, just how much oil did you loose?
Crank seal
G3 Thanks for the reply. I didn't loose much oil only down about 1/8" on the stick, only traveled about 3 blks. I went back and tracked the oil trail.
