Honda CL72 CL77 Seat Kit for 1962 to 1965 (early)
Sculpt Garage
Post by Sculpt Garage » Thu Oct 20, 2016 12:31 pm
This is a 99% Honda accurate multiple piece solution to get your 1962 - 1965 Scrambler seat to look like it came right off the assembly line. After years of researching Honda factory advertisement photos, studying both NOS and original seats, and straps, we’ve perfected a seat kit.
Our kit includes a one-piece foam, seat cover, strap, and installation hardware. See details below.
One-piece Foam:
Using modern day chemicals and technology, we made a better, more comfortable seat foam in the same shape and size as the original Honda equipment. Our kit eliminates the sagging and shifting of the multi-piece foam blocks used back in the day.
Seat Cover:
We designed our seat cover to fit like a glove around our one-piece foam. We’ve accounted for the stretch of the material, so you don’t have to, making installation a breeze. The marine grade vinyl we use on the cover and welt/piping is as close to original as we could find, taking in to consideration grain texture and size, as well as luster and sheen like the OEM. The welt/piping is accurately positioned, mirroring the “correct” seat cover.
Strap:
In 1962 to 1965, Honda used a shorter strap with incorporated clasps/buckles making it removable.  We went through the effort to integrate the steel internal, reinforcing band just like OEM. We didn’t take shortcuts in the stitching, it too is meticulous, replicating the stitch length and design.
Installation Hardware:
Rubber protective guard that goes around the bottom edge of your steel pan. Bolts, nuts, and washers for remounting your seat trim.
Not Included:
You supply your own pan, steel clasps/buckle, and decorative metal trim.
Helpful Hints:
If your seat cover attachment spikes are breaking off, we have another solution for you. For more information about these attachments contact us at: 512-577-3175
Cost $500.00+shipping Only accepting Pay Pal at this time
Click the link below for photos
http://www.ebay.com/itm/Honda-CL72-CL77 ... 2683415535
